Marjomar 0
Hi all,
I´m usin the HC2 heating panel to control de heating for all rooms using 6 POPP + 1 SSR303 + 1SRT322. It´s working great.
I had a room where I had electric heating and I will like to use the heating panel using as the room thermostat fgwp101(wall plug).
Now I had a script with a LUA code where I introduce the temperature but instead doing that I will like to use the heathing panel for that room.
Any idea how to do it?
Thanks a lot
I attach the Lua Code I had.
local boiler = tonumber(fibaro:getValue(8, "value"))
fibaro:debug('Estado del relé en la caldera: ' ..boiler);
local temp1 = tonumber(fibaro:getValue(58, "value"));
fibaro:sleep(1000); --
fibaro:debug('Temperaturas cargadas');
fibaro:debug('Temperatura Jose ' ..temp1);
fibaro:sleep(1000);
while true do
if (
( tonumber(fibaro:getValue(58, "value")) < 21 )
then
fibaro:call(8, "turnOn");
fibaro:debug('Caldera encendida');
if (
( tonumber(fibaro:getValue(58, "value")) >= 22 ))
then
fibaro:call(8, "turnOff");
fibaro:debug('Caldera apagada');
fibaro:sleep(1000);
fibaro:sleep(300000);
5 answers to this question
