Vic 0
Hi
What I want to do is to show from a variable to a ipad fibre display - for example i have setup a variable that changes on a scene called Alarm at Home - I want to display this as a on or off state some how on the iPad in fibre display so that you can see if the alarm in home mode is on or off (active or not active)
Just need a simple way to show the state of a variable visually - have tried doing it through a virtual device with no luck....
any help would be greatly appreciated..
