Push notifications doesn't have interactive part
Hi, I've setup push notifications to my phone after a scene is triggered. It displays a notification on my phone, but doesn't give me the option to run/cancel etc. Any advice gratefully received! Thanks
12 answers to this question
Hi @NeilR,
For interactive push messages you need to use this code:
For "mobiledevices" you need to setup mobile devices ID (one or more separated by comma) that will receive interactive message and you can find them here: http://<YOUR_HC2_IP>/docs/
For "category" you can use either "YES_NO" or "RUN_CANCEL" as far as I know.
For "sceneId" you enter scene ID that you will run if you press selected button "YES" or "RUN".
What @gucio1234 give you link for are popup interactive messages that show in mobile app inbox. They will not show on mobile device lock screen, so if you need immediate response it is better to use above code for push interactive messages since they show on lock screen or even on Apple watch (maybe also on Android wearable) and you can initiate action from there!
@Sankotronicinteractive push messages don't work as expected. your example works.... but without choice [yes] [no] - just simple push notification.
iPhone.
UPD: just tested on my old LGE Nexus 5
yes, it works!
Edited by 10der
iPhone.
yes, it works!
I tested code on iPhone before posting here and it works OK.
oops!
it's my fail!
I have checked this and it does not always work. Most of the cases there is popup on the phone but no action to select.
I tried "YES_NO"  "RUN_CANCEL"  "TAK_NIE"  (which is in Polish), but on the phone I got just pop-up without option to select.
I think the selection I received only once.
long tap (new ipnones feature) or see details (swipe)... and you can see that!
@10der thank you, it is working.
there's a tutorial done by Fibaro
Hi @Neil!
It depends on your phone, but basically, the thing what you looking for is called "interactive push" and here is a knowledge base article about it:
Hi all
is the above code still valid? i mean with the new IOS and android app can the interactive push work as expected?
with the native setup as per fibaro's doc the app doesnt give me the yes or no option with the notification
thanks
why interactive push notification work only on superuser mobile device and not any mobile devices logged in with regular user!!??
Edited by midrange
