Hi!
I have a Remotec Zxt-120, but I cant see the battery Status. The device has version 1.20. Have tried a reset and also deleting and adding the device again and again.
Anybody know what is wrong?
Guest chaicka
Did you accidentally set the ZXT-120 into FliRS mode?
Check the manual on how to change the mode.
    Thank you. Fixed now.
    • 5 months later...
    i faced a problem that ZXT-120  consumes batteries very fast ( just in 2 days ) while it is set to FLIRS mode ,, any explanation ?
    To make this change, the device have to be excluded from the network. Be sure that it is.
    i did so , till it pulse 2 pulses that means it entered FLIRS mode as Witten in data sheet, but unfortunately  after 1 day battery low then device is dead ! any help ?
    i have 8 remotec and all did so ! :(
