is the heat controller able to use another external source of temperature
Blackmurray77
Hi, i cannot use the integrated temperature sensor of the thermostatic valves, i need to use the temperature on another place of the room. Therefore i bought the heat controller, which should be able to use external source. But, on the market the external sensor for the heat controller isnt available yet and i have in the network a lot of another sources. Is it possible to use another source of temperature as from the original bluetooth sensor delivered to the heat controller? Thx
Hi @Blackmurray77,
You can use all types of Z-Wave temperature sensors.
Fibaro TRV should act simmilary to Danfoss TRV by principle of heating and by that i mean it will use internal sensor.
Edited by jakub.jezek
adding more accurate info v2. Removing Heatin panel info.
" to "
Temat został przeniesiony z "
" do "
