Robert S
Fibaro Flood Sensor Battery Life
I am using the flood sensors with Homeseer. I have set up the first one of five for a test. When it was first installed 4 days ago, I read 93% battery life. I am already down to 89%. At thew current pace, battery maintenance will be extreme. Is this usual behavior, or should I look at something to try to extend the battery life. I have not changed any of the default polling etc.
Share this post
Link to post
7 answers to this question
Hi, maybe you need to veryfy wake interval, default is 4000 seconds, but it's on Fibaro systems, maybe Homeseer need to wake this device  more often? You need to check temperature sensor as well.
I can see, that you're from Canada,  and the flood sensor is on proper Canadian frequency  (908/916) ? You can check setting of the LED indicator, default value for  63 parameter, default is "2".
Always you can try to use an extend power supply and remove the battery ;)
Chris
Share this post
Link to post
  • I have the polling settings at about 1 - 1.5 hrs - there are different settings for each alarm or component.
    Yes it is the Canada frequency (it does work)
    The LED is OFF
    External power supply is impossible, as it is in a bathroom, and no power is available where the device sits.
    What is the expected life expectancy of the devices
    Share this post
    Link to post
    After 3 months in use with HC2 and default values i had to change the battery of my flood sensor.
    And this is not the only battery device with this issue ; the keyfob and the smoke sensor are also not performing up to the standards/expectation.
    I would appreciate if somebody from fibaro could comment on what the possible cause could be for the short shelflive?
    What can we do to enjoy an extended battery live without loosing out on functionality?
    Share this post
    Link to post
    Did you setup the flood sensor with battery installed or did you hardwire it when setting it up initially.
    Share this post
    Link to post
    i am considering to connect my floodsensor to external supply. Any recommendation on how to proceed. What are the do's and don't do's.
    Are there ready to use solutions?
    Share this post
    Link to post
    I purchased this
    and used my own wiring/shrink-tubing to complete the job.  I did drill a hole (for the wires) in the lower half of the unit, just below the threads that the upper half use to connect.  I then used
     to make a good water seal around the wires.
    Only issue I've found is that my unit reports a 4% battery, even though there is no battery installed.  My 1st-gen SmartThings hub sends me a notification every few days, which is annoying.
    Another issue is that if I install a fresh battery (as a backup), it drains it from 100% to 4% within 24 hours.  Also, the unit will drain it's battery in 24 hours if it is reporting a flood event for all that time.  I guess there isn't a way to change it's settings (to fix this battery drain issue) without using a Fibaro hub.
    Share this post
    Link to post
