Temperature sensor on FGSD-002 and use without home center
I am using the smoke detector without home center (bought for looks). Did manage to test with smoke, so it does the basics.
First question is if the smoke sensor can be used with any iphone app without home center?
From the text below, i am not sure if the temperature sensor is disabled or is set to 55c ? . Did try to trigger the temperature sensor without success. If is disabled, how can i enable without home center?
Quote
Excess temperature detection
Apart from detecting presence of smoke, FIBARO Smoke Sensor has an additional function of informing of exceeding the programmed temperature threshold. The function is disabled by default in parameter 2 settings.
Excess temperature warning is defined by user in parameter 30 – set to 55°C by default. Excess temperature level can be also signaled by visual indicator glow (parameter 3) and short beep (parameter 4). Parameter 20 should not be set to 0 because such setting disables temperature measurements.
Thank you
