sir_horn 2
I use block scenes to set different dimmer levels during the day. I assumed that lights associated with Fibaro motion sensor automatically would turn off after the time set for alarm cancellation delay in the associated motion sensor but they stay on if they are turned on by a scen...
Now I'm thinking if I should use the timer function in dimmer2 (parameter 10). But I wonder how it would work in this case. Will the timer in dimmer2 turn of the light even if the sensor have recorded motions during the time set in the timer interval?
OK solution? will go for smart light scenes setups when I have a little bit more time
