Hello.
I have a  Fibaro rgbw. Every output is working perfekt exept W. It gives out power, but I am unable to turn off or dim it. It's allways on 100%. Someone know whats wrong?
Did you set in the device settings that the attached strip is RGBW?
Jim
    No. How do I that? I am using Razberry as controller
    Ah didn't know, then I don't know how to do this
    sorry
    I hawe no reaction witch switch also
    On 28.11.2017 at 6:57 PM, jimicr said:
    I have now tried a reset of the unit. The white outlet is still allways on with full power. Can it be something wrong with the unit?
    I have now tried with another one , and this one is working perfect. So it is something wrong with the unit.
    Glad you figured it out. Maybe you still have warranty?
