Hello, guys,
are there any possibility to configure summary consumption on dashboard bar. By default the the sum of the values is displayed related to all device which have function of energy metering. The point is that I have a smart meter on a main incomer (input) and it measures already the total consumption of all my electrical devices. So, it's enough for me to show only this value on the dashboard bar.
Edited by T.Konopka
Wrong category. Read descriptions of forums before posting.
5 answers to this question
" to "
Temat został przeniesiony z "
" do "
Please, read descriptions of forums before posting. You posted a question in a forum where users share their solutions.
Simply go to advanced settings of devices and untick the setting to include the devices in power consumption.
    @T.Konopka Thanks for advice and sorry for the wrong place of publication, next time will be more carefully.
    Did my advice help about the power consumption? :D Because I do not know if the "advice" you are referring to is about the issue or about forum :P
    No worries, this forum
    is a place where users share their scenes, VDs, etc with the community. So you can post there a solution you created so others can use it as well ;)
    @T.Konopka Your advice was correct (in my case definitely).  The problem is that I use RU language interface and it seems like a problem with right translation of a real meaning for considered parameter. "Untick" was equal for me to cancel power measurement feature at all, but it's wasn't my purpose, since it's rather convenient to see energy consumption for those or that devices. The problem was only to set up in a right way summary consumption on dashboard bar.
    My conclusion from this case, is that better to switch to EN language interface in order to understand paraments description in a correct way.
