is there a way to get the FibaroApp onto the samsung gaer s3?
If i got it right, it's an app only for android wear?!
Or can i get scenes onto the watch?
Edited by roelnic
Guest titopringles
@T.Konopka: Are there official plans to make a fibaro-App for samsung galaxy watch?
    +1Waiting for that too!!
    +2 (one for my wife)
    Guest dacianova
    +1 for me
    +1000000 !
    Just need to consider the number of samsung devices in the world
    Też bym chciał apkę na mojego Geara, niestety fibaro ma niedobory programistów od dłuższego czasu jak widać bo wiele jest zamkniętych projektów lub przestarzałych a to co poprawiane psuje inne. :)
    I would also like the app for my Gear, unfortunately fibaro has shortages of programmers for a long time as you can see because there are many closed projects or outdated ones, and what is being improved spoils others. :)
    Currently i have installed WatchMaker Face that has tasker integration.
    I have set-up scene activation tasks in Tasker directly to do "Get" API Calls using http://user/pass/api/sceneControl?id=xxx&action=start
    But this still depends on the phone/tasker.
    Watchmaker also supports LUA script so is there any one that knows how to do do http api calls using LUA script directly from watch?
    That would bypass the need for the phone apps, technically it can run over the watch wifi or ofcourse using phone tethered internet but not rely on installed apps.
    Hello, I installed the Wearable Widget application on my phone and watch (Galaxy Watch). I added the Fibaro script. The first start from the watch works correctly. At the second, "X" appears on the watch. Please help.
    Edited by Gabriel87
    Hello! If i get Gear s3 can i install this app onto it?
    And if not, which of these (
    ) watches are compatible with this app?
    Edited by GregR20
    update
