[SOLVED]Motion Sensor - scene doesn't work with 1800s
leighivins
I have a scene setup using two motion detectors to turn offfice lights on an off.  When i set the timer to 30s the scene orks perfectly, however. When i set the scene to 1800s which is the preferred timing, the scene does not work.
Any help would be much appreciated.
Leigh
