Netatmo plugin wind module not supported?
I got netatmo plugin on my F. HCL and there is no wind device on device list?
/deleting and adding again is not soliving/
Firmware 4.143 and 4.150 still same.
6 answers to this question
We've been waiting a long time for the Fibaro to add a wind sensor... maybe this year for Christmas ;-),  but we have already lost hope :(
In HC2 there is no problem because you can add your own VD but the problem is with HCL where you can't add VDs written in LUA.
Well, I miss only wind module in Fibaro plugin for Netatmo. Also i would sacrifice Netatmo thermostat to Wind sensor. :D
shilghtly OT:
Interesting is, thet there is Netatmo thermostat connected to Fibaro via plugin. I will be toying with it tomorow.
Is anyone working on solving the issues with the wind sensor?
Best Regards // Marcus
Since this issue is not solved yet, is here some possibility to use weather plugin to act wind gusts?
If you can access your HC2 with SSH you can upload these two files into /opt/fibaro/plugins/com.fibaro.netatmoController/. Then if you recreate Netatmo connection you will get WindStrength and WindAngle as two new devices.
Regards
is wind gauge from Netatmo still not possible to have in HCL ??
Josef
