Josef Mlaskac 0
i have about 75 device in my home that i have problem with freezing my home center lite (4-5 days working, then web admin interface colapsed). I buy the fibaro home center 2 as a try for solve it (i think that problem is that i control 22 heating valves, using 11 thermostats which controls 12 actors ) and sometimes can be home center lite busy (memory usage is 90%).
But im not able to transfer the home center 2 to MASTER of MASTER role, i can sync, i can set as master but devices are not "MINE". There is no advanced parameters which i see in oldest one home center lite
when i shut down home center lite by power switch all devices are aut.
There is no way to reconfigure home center 2 as master controler ?
second question is that adding second controler (home center lite) is for HA (high aviability ) or just for extend the range? I have idea to control everything from home center 2 and use the home center lite as "fallback" z-vawe controler to transfer functionality for basic things (control heating and control smoke and leak detector). But it doenst seems that fibaro has some of this "backup" functionality ?
thank you i try use many manuals and tutorials and every time when i shut down home center lite, devices are missing. 4 days of solving without success.
thank all for give me idea
here is existing message, hc is not primary controller -> but devices are unconfigurable.
HC (lite) is not primary controler, but still owns all devices. 24 hour of waiting for miracle (migrate them to the main controler) but no change.
Edited by Josef Mlaskac1 answer to this question
