Guest PedroRS
Hi guys,
From 1 year ago I have installed in may home five FGS-223 controlling all light and ALL of them are having the same issue.
Randomly they don't react to physical switch request. It means I manually turn off or on the light and the status is not changed (and no noise form the relay).
Sometimes second attempt is working fine but few time I need to switch tree times...
All are working as:
Switch Type 2 - toggle switch (device changes status when switch changes status)
Operating mode - Standard operation
Other configurations are basically default ones since I'm not controlling scenes, etc.
I'm using Zipato controlled, but it's directly controlled by the module as far as I know...
Any idea about the root cause?
Thanks for your support !!
16
7
6
Nov 10
13
Dec 24
10
Apr 25
8
Jul 28
5
Andrew Lockhart 27 posts
Robb 16 posts
jack.daniels 7 posts
marco87 6 posts
Nov 10 2019
Dec 24 2019
Apr 25 2019
Jul 28 2020
Andrew Lockhart
Just a quick update on this. After following the instructions given by the very responsive support person I am still having the issue where occasionally, I would guess once every 50 switches, the manu
Andrew Lockhart
Guess what. I've been working with Fibaro showing them videos of the problem and now there is an a firmware update available. v3.4 is available to download and I'm told that it resolves this issu
Andrew Lockhart
Yes, this is what I am seeing too. The switch always responds to being controlled remotely so I don’t think it’s a stuck relay issue. I’ve followed their advice this evening and changed para
90 answers to this question
