Multiple startup Scene
Hallo
please i need help with lua scene code for Multiple startup
i have fibaro Wall Plug and i need make this scene
8:00 turnOn, 12:00 turnOff, 14:00 turnOn and finish 21:00 turnOff
now i have 4 simple scenes
how write this with one scene (for sample ID is 127)
i need this periodically every day
thanks
Edited by T.Konopka
Wrong category. Read descriptions of forums before posting.
" to "
Temat został przeniesiony z "
" do "
8 hours ago, AZreklama said:
Hallo
thanks
One possibility is to set the switch on at 08:00 and then go on with "fibaro:sleep(14400000)",turn it off "fibaro:sleep(7200000), turn it on again, "fibaro:sleep(25200000) and turn it off again...
    Thank you
    i test this code
    %% autostart
    %% properties
    %% weather
    %% events
    %% globals
    local sourceTrigger = fibaro:getSourceTrigger();
    function tempFunc()
    if (
     ( ((currentDate.wday == 1 or currentDate.wday == 2 or currentDate.wday == 3 or currentDate.wday == 4 or currentDate.wday == 5 or currentDate.wday == 6 or currentDate.wday == 7) and string.format("%02d", currentDate.hour) .. ":" .. string.format("%02d", currentDate.min) == "08:00") )
    then
        fibaro:call(37, "turnOn");
        fibaro:call(37, "turnOff");
    setTimeout(tempFunc, 60*1000)
    if (sourceTrigger["type"] == "autostart") then
    tempFunc()
    else
    if (
    then
