[SOLVED]Need Scene for bathroom radio
Hello everybody
I need a scene where the following happens
If motion is detected, a button in a VD should be started
If there is no more movement in the room, a timer should start, which when it expires again starts a button in a VD.
The goal is that my bathroom radio is turned on when I enter the room and when I leave it it goes out after a short time.
The whole script should be as simple as possible.
The best would be if the whole thing would happen at a certain time because the radio in the time between 22:00 and 5:00 should not tackle.
Can anybody help me with this ?
5 answers to this question
56 minutes ago, Bodyart said:
Hi @Thomasn,
I woul'd like to use such piece of code if you woul'd like to share it :-)
%% autostart
%% properties
128 value
127 value
%% weather
%% events
%% globals
local radio = 147; -- Fibaro plug with radio
local pir = 128; -- Pir in bathroom
local starttimer = 40; -- Time for radio to play in seconds
local timer = (starttimer); -- timer for loop
if (fibaro:countScenes()>1) then
    fibaro:abort();
-- Start program ———————————————————
if (( tonumber(fibaro:getValue(pir, "value")) > 0 )) then
      fibaro:debug(“Movement. Starting radio”)
    fibaro:call(radio, "turnOn”);
-- loop start —————————————————————
    repeat
           timer=timer-1;
           fibaro:sleep(1000);
        -- If movement then reset time ————————
         if (tonumber(fibaro:getValue(pir, "value"))) > 0 then
             timer=starttimer;
             fibaro:debug(“Movement. Time is reset”);
    until (timer<1)
      fibaro:call(radio, "turnOff”);
      fibaro:debug(“No movement. Program terminated”)
-- Some of the "--" have been changed during the upload to "--". Change them back or the program will not work. The "- -" (no space and no quotation marks) statement is used in lua script to insert comments.
Edited by Thomasn
" to "
Temat został przeniesiony z "
" do "
What radio are we talking about? I have a lua program that does what you ask for. It is triggered by a Fibaro eye and a Sonos One will start a radio program. It work as long as someone is in the bathroom and will end 60 secs after movement stops.
Is that something that you want?
Hi @Thomasn,
Thanks @Thomasn,
already playing with it. Shanks for sharing :-)
