Hi
Have not dig into it yet. But is there anybody out there that knows what LUA versions there are in the different HC2  firmwares? Asking as I am looking at LUA features that does not exists in to old versions. For example "Variable Number of Arguments" with function calls like function xxx(yy, ...) I had a few other things on my mind as well.
Any one?
Tnx in advance
/Peo
10 answers to this question
Should help :)
my result is on HC 2 v4.150
Guest spazpeker
That's weird my HC2 also v4.150
fibaro:debug(_VERSION)
says
[DEBUG] 18:02:30: Lua 5.1
    It seem I on 4.150 have 5.1
    Why do these versions differ between the same HC2 firmware? Fibaro staff????
    How can I raise my LUA to your version @PreHack ?
    11.2014   I got my HC 2
    04.2015   got it replaced
    05.2017   did a full reset and set it up from zero
    Did every update and often even beta
    I'm not sure why I have 5.2, I found out it is only in scenes. I get 5.1 in VD.
    Edited by PreHack
    Thats makes it even more strange. My HC2 is ordered january 2017, is fully updated to 4.150. And as said, I have LUA version 5.1
    A response from Fibaro would be appreciated here...
    Tnx
    Peo
    Ahhh. I have not checked in scenes, just VDs. Maybe another sandbox environment
    /Peo
    In VD's it gives      5.1
    In scenes it gives 5.2
    Running on FW 4.150
    Seems to be right, in a scene the goto statement works, but in a VD I get an error :(
    Lua engine is not the same for scenes and VD... Don't ask me why, Fibaro mysteries :>
    Running on FW 4.150
    Same versions here on 4.140
