I have some scenes that send me a popup notification "To many instances scene..." and I can't understand why.
Some one can help me please.
--------1st scene ------- Send Push Notification -------
%% autostart
%% properties
14 value
22 value
35 value
14 armed
22 armed
35 armed
%% weather
%% events
%% globals
if (
 ( (tonumber(fibaro:getValue(14, "armed")) > 0 and tonumber(fibaro:getValue(14, "value")) > 0) )
or
  --- Envio de Mensagem Push ---
then
    fibaro:call(11, "sendPush", "Detetado Movimento no Hall");
    fibaro:call(54, "sendPush", "Detetado Movimento no Hall");
--- Sensor Quarto SonyAlex ---
if (
 ( (tonumber(fibaro:getValue(22, "armed")) > 0 and tonumber(fibaro:getValue(22, "value")) > 0) )
or
then
    fibaro:call(11, "sendPush", "Detetado Movimento no Quarto SonyAlex");
    fibaro:call(54, "sendPush", "Detetado Movimento no Quarto SonyAlex");
--- Sensor Escada Cave-R/Ch ---
if (
 ( (tonumber(fibaro:getValue(35, "armed")) > 0 and tonumber(fibaro:getValue(35, "value")) > 0) )
or
then
    fibaro:call(11, "sendPush", "Detetado Movimento na Escada Cave-R/Ch");
    fibaro:call(54, "sendPush", "Detetado Movimento na Escada Cave-R/Ch");
---------------------------------------2nd Scene -----------------------------
%% autostart
%% properties
134 value
%% weather
%% events
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
function tempFunc()
if (
 ( (tonumber(os.date("%H%M")) >= tonumber(string.format("%02d%02d", "07", "07")) and tonumber(os.date("%H%M")) <= tonumber(string.format("%02d%02d", "09", "00"))) and (math.floor(os.time()/60)-math.floor(1512630420/60))%60 == 0 )
and
 ( tonumber(fibaro:getValue(134, "value")) > 0 )
then
    fibaro:startScene(18);
    setTimeout(function()
        fibaro:startScene(20);
    end, 30000)
        fibaro:startScene(43);
    end, 180000)
setTimeout(tempFunc, 60*1000)
if (sourceTrigger["type"] == "autostart") then
tempFunc()
else
if (
 ( (tonumber(os.date("%H%M")) >= tonumber(string.format("%02d%02d", "07", "07")) and tonumber(os.date("%H%M")) <= tonumber(string.format("%02d%02d", "09", "00"))) )
and
or
then
    end, 30000)
    end, 180000)
Thanks in advance
Alex
Don't try to understand. Multiple instances are very frequent. Just put this code at the start of your scene:
if
  fbaro:countScenes() > 1
then
  fibaro:abort();
