Javier Carelli 0
Good morning Dear, I want to start with the lua programming and I can not find a way to do it, especially to solve these 2 problems, which seem simple but I can not find the solution:
1- I tried with block scenes to light 2 exterior lights 15 minutes before sunset and turn off 5 minutes after sunrise. For this, create 2 scenes 1 to turn on the lights and others to turn them off. The shutdown scene works correctly and leave it in block mode. I have the problem in lighting the lights at night, the only way to turn it on is if I deactivate the scene and turn it on (I DO NOT KNOW WHY I HAVE IT AS AUTOMATED).
Attached the scene of the shutdown is the same as the ignition, except that the ignition I put that if it is night and the lights are off then they turn on
2- The other scene is with the Door Windows to turn on the lights when they open, the problem is that when it remains open the door does not turn off the lights. For that create another scene that when it detects that the door is open more than 5 minutes to turn off the Light, the problem I had is that if it does not close it turns on and off every 5 minutes.
Thank you very much!
Best regards!!!
Edited by T.KonopkaWrong category. Read descriptions of forums before posting.
