I use a ZIPABOX and I would like lock my key fob FIBARO with square/cross/minus.
For unlocking the value of parameter is 345 and for lock is 60 for autolock after 60 secondes.
But the keyfob never lock. In the documentation fibaro, there is to "set PROTECTION Command Class to Local Protection by Sequence" for enable the mode lock on the key fob.
Can you tell me if the fey fob is all compatible with ZIPABOX ?
Thanks,
you'd have to email zipato support and see if they have a profile for it yet.  before moving to Fibaro, i used zipato and they are pretty quick with their responses concerning compatibility of other manufactures' devices.
