I recently bought a home server lite. its on firmware 4.150
but i cant get the time right. I tryed a few timeservers, i changed it to manual but it keeps getting to 1-1-1970 1:00 (it starts here after the reboot)
i dont know whats wrong? does anyone know what i can do to solve
this problem.
thanks
Edited by TSN
Wrong text
Sry. Saw that you have hcl. My workaround is only for hc2, so i edited the post
Edited by redbill
See post
I am not familar with the HCL but can´t you change NTP in the settings? If yes, then try 0.pool.ntp.org. It works for me.
    no problem redbill, at least thanks for the try/think work.
    @Thomasn thx for the reply.
     tryed that to, but no improvement. i tryed alot of NTP servers, but nothing helps.
    I think it has something to do with account configuration. I cant get tru account setup eather.
    and i found out that lots of parameters cant be changed.
    i dunno whats wrong....... Fibaro has been mailed.... so lets hope they can solve this..
    Edited by TSN
    Hi @TSN,
    Can you try to set time manually and set it to NTP? That one help me from time to time.
    On 22-12-2017 at 9:44 AM, jakub.jezek said:
    Hi @TSN,
    Hi
    thanks for ur answer.
    I did tryed that several times but no improvement.
    Fibaro mailed me back, it seems to be a known problem, and it shoud prob be fixed in the next update. so lets hope it wil,l and lets hope the update will come soon. else i will quit on fibaro.
    This is just the tryout, so i will move upto HC2 but not if small issues get solved very soon. Like the time is a small issue, but with big effects.
    The trust in Fibaro is getting realy low, cause scene's seem to work, and the other day they wont,,,, so WTF????
    Push notifications worked great till yesterday, now i only get notifications (alarms) when i open the app....???????
    I dunno bout Fibaro, it might not be that great after all...
    Greets TSN.
    Hi @TSN,
    There were bigger issue with time few years ago. Some HCLs showed me year 2025 and some 1970. But it got resolved in past. Now so far, you are one of the unlucky ones with this issue. I have quite a number of success with time settings (NTP -> Manually > NTP).
    Ok, could you be more specific about this one? Maybe if you create a topic for this in Home Center lite section with description, what is not working, maybe I or anybody could help you out.
    I never had this problem in past, except when Fibaro cloud was offline. Did you made any changes in notification permissions?
    Best regards,
    Jakub
    1 hour ago, jakub.jezek said:
    Hi @TSN,
    My HCL shows me 1970 in the right top corner, but at the energie logs and temperature logs it shows the right time (didnt before). And i did get the time quite right, by rebooting the HCL at 1 o'clock at night :)  but the date is still wrong...
    So this might come from the weather app. while im typing this i rebooted my HCL again, and somehow he got the time right now???????  only thing i realy changed is my housenumber...????? So forget bout this problem!!!!
    This is by far the best working forum i have ever seen.... ;)
    Quote
    Got it working again
    I might have to come back at this, im working on it now, it seem that it sends an old push notification now (an old text i wrote a while ago) but i cant find it no more, so somehowe i deleted the push notification, added a new one now. But it still sends the old text.
    Do u still get it??? LOL so i keep searching/working on this one.
    Now that the time is right, maybe it chages alot of weard effects, ill keep working on it for a while!!!
    Thanks for ur help so far, this made my day.
    TSN
    Hi
    This changes alot, now that the time is right. Now i finaly finished my wizard HC and got this code from fibaro etc etc. coudnt get it finished before eighter.
    so i do think this changes alot in the Fibaro expierence.... so i'll give it a go.
    Although im not sure what the problem was, im glad it solved alot today.
    It might be the YR weather app, somehow it got in twice. but this wasent when the HCL got out of the box sooo..... im not sure (time was wrong from the beginning) .
    Thanks for helping out.
    Regards TSN
    Edited by TSN
    wrong words
    Do not worry. Memory is short :D.
    If it happens again, then maybe recovery would help. But to me it seems like getting cannon for a mosquito.
    Recovery is same for HC2 and HCL:
