Message at reboot
Thomasn
have anyone succeeded in making a script in lua - or perhaps a vd - for sending a message/notification when the hc2 has ben reset?
The reason I ask is that my hc2 is running a small program, which reboot the hc2 every Sunday morning. But it would be nice to recieve a message when it has been done.
Edited by Thomasn
I mean, I don't think it's something that should be introducted by us to all Home Centers.
Maybe it's easier for interested users to make a scene with such push notification:
First, we make a variable:
Then we make a scene:
Let me know, did I understand you correctly and whether this solution satisfies you ;  )
You can have autorun scene that will run at boot time and send you message that HC2 has been restarted. I can't think of simplest way to get notification that HC has been restarted.
Also you can check time for how long HC2 is up and running by getting settings info with this code:
Above code formats calculated time to show in days, hours and minutes same as on Configuration General tab -> server status.
Edited by Sankotronic
Corrected typo in above code
  • Thank you to the both of you. Exactly what I was looking for.
    /Thomas
