[SOLVED]Scene - turn on only once at a specific time
Hello
I need to create a scene that will be every day in the morning between 7.30 and 9.30 checking if the motion detector is violated, if so it will trigger some reaction, but only once a day.
Therefore, it is definitely necessary to make a variable that will change the value after the violation from 0 to 1
Unfortunately, my beginnings with Lua are difficult if anyone could help me to sort it out to start working?
%% properties
%% events
%% globals
if fibaro:countScenes() > 1 then
 fibaro:debug("SCENE ABORT --------------------------")
function toMinutes(czasHHMM)
local a
if type(czasHHMM) => "07:30"
if type(czasHHMM) =< "09:30"
      then
      fibaro:setGlobal("rano", "0")
      else
      fibaro:setGlobal("rano", "1")
fibaro:sleep(60*1000)
    ok i tru and morning time trie :)
    let's wait a few days out of curiosity.
    no i have test 4 day
    Working good :) !!
    Edited by 10der
    and can I ask a small description . :)
    done
    btw, is code for "motion detector is violated" should di provide too?
    :D
    here is my sample code for newcomers.
    Thank you very much, I added a motion sensor to the start.
    but something does not work because I do not write :) hello after the move :(
    Of course, instead of saying hello, I would like to throw in a welcome note from Sonos in the morning - but first I would like it to work once in the appointed hours on the motion sensor :)
    Will you help my friend?
    %% properties
    %% events
    %% globals
    %% autostart
    17 value
    17 armed
    if (
     ( (tonumber(fibaro:getValue(17, "value")) > 0 and tonumber(fibaro:getValue(17, "armed")) == 0) )
    or
    then
    function between(str)
          -- get current time
        local t = os.date("*t", os.time())
          -- grep input params and separate on hh mm start and hh mm end
        local h1,m1,h2,m2 = str:match("(%d+):(%d+)-(%d+):(%d+)")
          -- some magic - pure mathematics.
        m1, m2, t = h1*60+m1, h2*60+m2, t.hour*60+t.min
          -- check possible variants
        if (m1 <= m2) then
          return m1 <= t and t <= m2 -- 01:00-02:00
        else
          return m1 <= t or t <= m2 -- 23:00-21:00
    -- not executed by default
    local executed = false
    -- infinity loop
    while true do
        -- check is period active
          if between("22:00-22:30") then -- yes active
            -- if not executed
            if not executed then
                  -- just do it
                print("Hello!")
                  -- set what we already executed in this period.
                  executed = true
        else -- not active
            -- propbably we exit from work period
            -- mask as not executed and waiting for next hop
            executed = false
          -- every 1 min
        fibaro:sleep(1000 * 60);
    I am sorry, are looking attached post?!!!
    PS: do not use any params at header when your use  infinity loop
    no print here
    just click on link
    Edited by 10der
    I act so but unfortunately, a lamp lights up every movement.
    and if I had just implemented that it has to read something once in a while - it will do it every time it detects motion and lights turns on
    so. as I can understand you won't turn off lamp automatically, right?
    I am including - but something else.
    I need to do this properly. :)
    in the morning I go down the sensor detects me between 7.00 - 8.00 am
    the Sonos command is sent.
    read about it through TTS - what is the weather outside. - I know how to dress :)
    and I turn on the radio by calling the button.
    But I need it to be turned on once...
    simple: Save action datetime to Global params and check before
    IMHO that really simple
    I'm just trying to do it but my adventure with the lua is just the beginning.
    no, it does not really come to me, that's why I'm trying to advise you here - because I do not have any undertod global params
    Edited by wojtas810
    Hi thanks for your help me
    but i do somthing wrong
    This is all my scen
    %% autostart
    %% properties
    17 value
    %% weather
    %% events
    %% globals
    local when = tonumber(fibaro:getGlobalValue('I_got_up'))
    local daysfrom = os.difftime(os.time(), when) / (24 * 60 * 60)
    local wholedays = math.floor(daysfrom);
    print(wholedays) -- 0 today > 0 next days
    if wholedays == 0 then
          -- nothing todo
          -- waiting tomorrow
    else
        -- play
        -- save current datetime
        fibaro:setGlobal("I_got_up", os.time())
    local sourceTrigger = fibaro:getSourceTrigger();
    function tempFunc()
    if (
     ( tonumber(fibaro:getValue(17, "value")) > 0  and  (tonumber(os.date("%H%M")) >= tonumber(string.format("%02d%02d", "15", "00")) and tonumber(os.date("%H%M")) <= tonumber(string.format("%02d%02d", "16", "45"))) and (math.floor(os.time()/60)-math.floor(1513438320/60))%10 == 0 )
    then
        fibaro:call(391, "setSlider", "15", "8");
        setTimeout(function()
            fibaro:call(391, "pressButton", "24");
        end, 25000)
            fibaro:call(391, "pressButton", "7");
        end, 28000)
    setTimeout(tempFunc, 60*1000)
    local sid, bid = 391, 28
    local cond = fibaro:getValue(323, "WeatherConditionConverted");
    local tempext = fibaro:getValue(323, "ui.lblTemperature.value"); -- température extérieure
    fibaro:debug ("Temperatura na zewnatrz: "..tempext)
    local degre = string.gsub(tempext, '[,]' , ' degré ')
    local degre = string.gsub(degre, '[.]' , ' degré ')
    local degre = string.gsub(degre, '[-]' , ' moins ')
    local jourL = {"Niedziela", "Poniedziałek", "Wtorek", "Środa", "Czwartek", "Piątek", "Sobota"}
    local jour = jourL[currentDate.wday]
    fibaro:debug ("Dzień : "..jour)
    local moisL = {"styczeń", "luty", "marzec", "kwiecień", "maj", "czerwiec",
                   "lipiec", "sierpień", "wrzesień", "pażdziernik", "listopad", "grudzień"}
    local mois = moisL[currentDate.month]
    fibaro:debug ("Miesiąc : "..mois)
    local condfr = fibaro:getValue(323, "ui.lblForecast.value");
    if( cond == "clear" ) then condfr = "czyste niebo"; end
    if( cond == "cloudy" ) then condfr = "pochmurnie"; end
    if( cond == "rain" ) then condfr = "deszcz"; end
    if( cond == "snow" ) then condfr = "śnieg"; end
    if( cond == "storm" ) then condfr = "burza"; end
    if( cond == "fog" ) then condfr = "mgła"; end
    fibaro:debug ("Conditions météorologiques : "..condfr)
    fibaro:debug ("co mówi TTS ")
    -- Create TTS params object
    local params = {
      -- TTS Message
      message = "Dzień Dobry Wojku, Kasiu, Zosiu,"..jour .." "..currentDate.day .." "..mois ..
                ". Teraz jest ".. currentDate.hour .." godzina i  ".. currentDate.min .." minut. "..
                "Na zewnątrz termometr ma "..degre ..
                ", a za oknem przewidywana jest  "..condfr ..". ",
      duration = 'auto',    -- Duration: "auto", xx seconds
      language = "pl-PL",    -- Language: fr-FR
      volume = 40            -- Volume
    local _f = fibaro
    local _x ={root="x_sonos_object",load=function(b)local c=_f:getGlobalValue(b.root)if string.len(c)>0 then local d=json.decode(c)if d and type(d)=="table"then return d else _f:debug("Unable to process data, check variable")end else _f:debug("No data found!")end end,set=function(b,e,d)local f=b:load()if f[e]then for g,h in pairs(d)do f[e][g]=h end else f[e]=d end;_f:setGlobal(b.root,json.encode(f))end,get=function(b,e)local f=b:load()if f and type(f)=="table"then for g,h in pairs(f)do if tostring(g)==tostring(e or"")then return h end end end;return nil end}
    -- Make a request to the remote to process params object instantly
    _x:set(tostring(sid), { tts = params })
    _f:call(sid, "pressButton", bid)
    if (sourceTrigger["type"] == "autostart") then
    tempFunc()
    else
    if (
     ( tonumber(fibaro:getValue(17, "value")) > 0  and  (tonumber(os.date("%H%M")) >= tonumber(string.format("%02d%02d", "17", "30")) and tonumber(os.date("%H%M")) <= tonumber(string.format("%02d%02d", "17", "45"))) )
    or
    then
        end, 25000)
        end, 28000)
        -- play
    and how will you help? my friends ? @10der
    Dzien dobry!
    co nie dziala?
    my scene above what I inserted above
    so, you propose to me install your scene, understand what is 17 device, buy sonos and debug?
    instead of attending to just provide error or clear say what happens.
    thank you understanding.
    sorryi, I did not mean it.
    I used your example.
    I pasted what I'm interested in, i.e. every day between xxx and yy when I detect motion, I want to turn on the sonos radio once - and not repeat it anymore.
    I do not know what I'm doing wrong. because after all, the scene is turned on every time it detects motion.
    sonos works fine.
    but I do something wrong or I do not know anymore.
    That's why I gave you the whole scene - because I thought it would be better
