kmeta 2
Hello guis
I just integrate new device in my Fibaro controlled home. It's Wi-Fi Universal Remote control + Temp, Humidity, Lux and Motion sensor.
There is the code for IR control. I make test with TV but also is possible to command Air-conditioner.
There is sample of Power on button. It's really easy and simple:
First: You can use Shelly Application to add IR codes to the sensor. After that you can check the ID's of the remote control using http://localIP/ir/list, or to know the PRONTO code for each command.
Also make VD witch show the status of the sensors.
It's works well i hope could be cheap solution.
