Good day,
I have a Fibaro Single Switch for Apple Homekit, which I would like to use as a push button. How can I accomplish this?
Best regards
Hello @Tom Nuggat!
Welcome to our community!
I don't know whether I understand what you mean by a "push button" but maybe try this out:
Go to our Single Switch Settings in Fibaro for HomeKit Devices app:
Then, change the Switch Type to "Monostable":
Please write back if this is what you were looking for ; )
  • 3 months later...
have you been able to solve it?
I have the same issue, please check:
I have changed the Switch Type to "Monostable" but it does not send a power pulse to the load but once activated it gives continuous power to the load.
What shall I do?
Thanks,
dan
Guest chaicka
A long shot but not unreasonable (due to the HK Door Sensor same behaviour for one setting). The change in switch type does not take effect until a power cycle of the module.
