Alternative for C-Bus 4 channel analogue output, 0-10vdc
Hi guys,
Wondering if any of you are familiar with C-Bus system? Attached with the product info
Is it possible to replace "C-Bus 4 channel analogue output, 0-10vdc" with Fibaro products such as dimmer or RGBW?
As I know it seems to be no.. since RGBW 0-10V is input but not output..
Thanks!
Edited by T.Konopka
Wrong category. Read descriptions of categories before posting.
4 answers to this question
" to "
Temat został przeniesiony z "
" do "
Guest spazpeker
18 hours ago, jamietang said:
Hi guys,
Thanks!
Qubino do a 0-10v dimmer module
You want to replace that unit? You'll have to test it... but an RGBW with 12 V supply might work, if you are prepared to do some diy. The output of the RGBW is PWM. On ebay, amazon, aliexpress you can buy converters. They filter the PWM and produce an acceptable 0-10 V analog out. It is a bit messy though, adding wires and stuff... To be tested.
    oh! didnt know that, thanks for the suggestion, will look into it.
    Thanks for the info Peter! Sounds not easy for me as im not an electrical guy.. but probably I'll try it when im free enough sometime..
