Scene to unlock lockwood doorlock - iPhone widget error
Hi
I am trying to create a scene whereby after activating the scene I would like the lockwood lock to unlock via the iPhone widget.
I am able to run the scene fine through the app, however when I try to use it as a widget on my iphone I get a "Communication error" message. Any ideas why this is? LUA code as per below.
if (
 ( tonumber(fibaro:getValue(31, "value")) == 255 )
or
then
fibaro:call(31, "unsecure");
Edited by serrzy
    Any ideas anyone?
    You can check this and see if it helps with programming.
