I have a HIKVISION Camera DS-2CD2385FWD-I and I wonder how I can add it to the HC2 as there is no plugin for that camera.
Any thoughts?
I would try the HiKvision DS2cd2132i - it must be close enough.
    There is one called Hikvision Ds2cd2132i and one Hikvision Ds2cdd2712fi
    Tried Hikvision ds2cd2132i - can't see any pictures/streaming on the HC2 . When I take a picture (email it to myself) its only 2kb small and it can't be open...
    Edited by texan
    You have to know the camera’s MPEG stream. Look in the manual. That stream you will have to write into the plugin.
    Edited by Thomasn
    The camera's sub-stream/mjpeg is following
    /Streaming/Channel/102
    If I type this into VLC media player it will show the stream
    rtsp://username:password@IP/Streaming/Channel/102
    But I can't get any pictures/stream in the HC2
    Edited by texan
    Does your Hikvivion provide a mjpeg-stream ?
    In some cases, you need to add the port to the ip (e.g. 192.xxx.xxx.xxx:80)
    It says on the Sub-stream, video Encoding - MJPEG, so that must be mjpeg stream?
    Tried with port :554 (rtsp) in the IP address field, and Streaming/Channels/102 in the MJPG stream path, but with no luck
    Fibaro does not support mjpg and jpg over rtsp. You need mjpg and jpg over HTTP protocol.
    :D Got some pictures from the camera, with /Streaming/channels/102/picture - better than nothing
    • 5 months later...
    It's working with
    Adam
