Device Grouping
Hi guys!
Is it possible to group 2 devices so that they can control each other?
I have a MCO panel switch and an Aeon Labs LED bulb. When I press the MCO, the LED bulb should be switched. When operating the LED bulb via VD, the switching state of the MCO should also be changed.
Currently only one device (master) can switch the other device (slave).
You have to use associations. Try to use the multi channel Endpoint1 Group 2 on both devices. That should make them speak to each others.
