Net.FHttp used in scenes
Please integrate this into the scene. "Net.FHttp".
Thank you.
9 answers to this question
Edited by 10der
I see it as a VD, not a scene...
    i need a scene for it is easier because in one function you can not fill the local variable.....
    whats the difference to net.HTTPClient?
    Can you please elaborate a bit, what are you trying to achieve?
    Edited by Bodyart
    Hi
    Already in the second line I have everything I need. I can handle everything in a local variable and do whatever I want.
    Here I can do everything only in this function inside except the function gets loaded no variable. it's not just my god it's thunderstorm several members then request that's also involved in the scene
    It's called cognitive dissonance. :)
    all http requests in VD work synchronize, but all http requests scene work in async mode.
    so, you should re-write your application using asynchronous design methodologies...
    Hello I understood that everything only why the difference to wd  and scehnen?
    that comes from many users. Why not integrate that into scenes?  Functions should apply everywhere, not one for WD and the other for scenes.
    I often need the synchronous variant as the asynchronous. I often need the synchronous variant as the asynchronous
    Thank you.
    " to "
    Temat został przeniesiony z "
    " do "
