I want to use a Switch 2 as a replacement for the exsiting manual Light switch and during this changing the single manual switchint a dual one.
Can I now use physical actor (connected to S1) to switch on the light as before and use the second physical switch (connected to S2) to switch on/of a second Switch 2 placed in a wall power connector using a z-wave controller?
-- Tolotos
Short answer: Yes.
Use associations if there is no power cords between the two switches - or make a little scene.
