We have an urgent customer requirement to control Philips hue with Home center lite, so that customer can control Philips hue and RGB strip in a single scene to have a common color. Can someone help us with a solution and required files?
I have a HC2 and created a virtual device with preset settings for the Philips hue lights to be possible to use theese presets in scenes, you need LUA for this.
I just bought a HClite too, and tried to import my Virtual device from HC2, not possible because of the LUA coding not supported by HClite
So I guess this won`t be possible, if not fibaro could make this happen another way in the future. The Philips hue lights works the same way in HClite as HC2, but not avaible in scenes.
    I am able to create on-off buttons for Philips Hue in HLC (home center lite) . But now I want to use it in scenes and want to control the color, which should be similar to the color set by RGB controller for a strip light. After adding hue in HCL, I am sure HCL supports it, we just need to figure our right string.
    • 1 year later...
    Hi. I'm trying to make this, the on /off for the lamps, not the ones from the fibaro plugin, other avalilables for scenes. If you done may be you wish to share the solution.
    Thank you
    Edited by baliya
