I have just got a Heat Controller as a gift.
However, our home has RAVL valves with a diameter of 26mm.
The Heat controller does not have an adapter for this type.
Has anyone got any experience with this problem and how to solve it?
I really like the Fibaro Heat Controller and would be sad to have to go for another option.
4 answers to this question
I had 28mm valves. I went to the local Central Heating shop and they had 28mm -> 30 mm adapters.
Maybe there are also 26mm -> 30mm adapters. Try it! Google is your friend.....
German Amazon has this one:
    I will drop by and pick one of these up on the way home:
    Otherwise, I will try yours Jakub
    Hi ironHipster.
    I'm in almost in the same sitiuation as you, i've got a RAV 34mm.
    Did you get any of the two solutions above to work?
    / UniChaos
    Edited by unichaos
