Unwanted action X button
Hello, I am using fibaro key fob to control rgbw controler and Hue bulb. X button is assigned to hue bulb and changing brightness only. I noticed that when RGBW controler is off, bulb is on and I pushed key fob X button then Red colour is on. If RGBW and bulb are on when I push X button-action going to bulb and RGBW is off and sometime is getting red.
5 answers to this question
Hi @Janech ,
I'm not sure if I understand you correctly. Pressing the X button on your KeyFob should only change the brightness of your bulb, and instead it does that but it is also turning the RGBW red?
    Yes it was,  you understood correctly. But now after last update my system is in a dust.
    What do you mean by that?
    Hi Mr Smolinski, I meant that since last to updates 4.170 and 4.501 Hcl is down and nothing is working.
    In that case, please, contact our support at
    I'm sure they'll provide you with a solution.
