keyfob battery bleeds out
Leike Lodiers
11 answers to this question
Hi @Leike Lodiers ,
We're currently working on this case. At the moment, I can;t provide you with any solution, but I can assure you that we're doing our best to resolve it.
I have a similar problem.
The battery in the new keyfob lasted exactly 7 days!
Does anyone know where the problem might be? :(
HEEELP ME PLEEAS :( :D
@T.Konopka Hi, is there any progress with finding solution on battery drain in keyfobs ? I just installed 4 brand new keyfobs and all of them got drained to zero within few days (less than a week). It is not acceptable to replace batteries every week :(
Same problem with the keyfob. Batteries goes flat far to quick.
I stopped using it. it is just too costly.
I hope they find a solution for this otherwise a waste of money.
I also have a problem with discharging the battery.
Month and battery to be replaced.
No problem here. Do you guys have a wakeup intervall setting? I have no wake up intervall (0s) and the first battery since over 1 year. I'm using it about every 2 days.
Good tip.
Please, follow it and get back to me after some time. Let me know if anything changed.
This method does not work because I have it for a long time and the battery is discharging.
