meute 2
I have just put in service 8 "Heat Controller" with external temp sensor and the 2 or 3 first days the regulation was working, not very well, with big overshot and abnormal temperature variations ... but the valve motor was reacting to setpoint change and room temp change.
Today, since this morning, the 8 valve are not regulating anymore, if I force it to close > they close, if I force it to open > they open, but if I give a setpoint in "HEAT" mode the valves stay closed (for hours) and the setpoint is 3 or 4 °c higher than the measured room temperature.
The window opened sensor mode is completely disabled.
Calibrating again changes nothing, going to standby mode and come back to working mode changes also nothing.
I don't know how to make it working again, for sure a factory reset should help but in 2 or 3 days I will get the same problem, and if I made a factory reset I must reconfigure all that part in my Home controller system. (I use Jeedom).
Also it's not admissible that the only solution to upgrade the firmware is to use a fibaro HC ... If you sell modules with firmware bugs you must provide solution to update it to all customers and not only for the customers who use your HC. With special tool by USB or all other possible solutions.
Edited by meute25 answers to this question
