Hide the "on/off" switch?
I am measuring the Energy consumption of my Media Devices via Fibaro Wallplug. To avoid switching off the power by accident, I would like to hide the "switch". Is that in any way possible? I do not want to set parameter 1 to "always on" because I still want to be able to switch the power off by scene(s). I do not want to hide the entire device because I like to see the power consumption values.
Does anyone have a solution for my "problem"?
Cheers, Jens
4 answers to this question
Have you tried this?
    thank you for answering, but no, as I said above, I do not want to hide the device because I want to see the consumption values. I guess there is some other option to maybe hide the device itself and display a "dummy device" which only shows the consumption values?
    Use it this!
    thx, but see above, I also do not want to set parameter 1 to always on because I want to be able to switch it off using scenes.
