RAM Usage issues (4.150) again
Software Version:4.150
@T.Konopka
or smb, can help me solve this issue.
Thank you!
PS: I do not want reboot HC2 every night, that still doesn't solve root of the problem!
5 answers to this question
Guest chaicka
@T.Konopka
Thank you!
Not too sure what issue you are trying to raise. 23% of free space in memory, that's pretty good and not the root cause of your system's instability (if that is what you are complaining). In many posts within this forum, esp. those in the early days of version 4.0xx, this topic has been greatly discussed at great length.
As RH_DreamBox has mentioned, most of the time HC2 is unstable due to poorly written scripts/scenes and overly congested z-wave traffic (which till date, I still believe it is single-thread on the z-wave layer). Just for reference purpose, a HC2 system running with less than 5% free space can still be very stable and operates without issue.
I think you have to go through your scenes very carefully to see if you can find something that needs to be corrected. (or a lot of log-data)
From my own experience, I know that you can get rid of memory very quickly with an poorly written code.
I tested once with an bad loop and the memory run out after a few seconds and then locked the box.
Then, I had a lot of trouble turning that scene off before the box was locked again ;D
Edited by RH_Dreambox
Agree with @RH_Dreambox
 I have alot of VDs and many LUA written scenes as well as graphical onces. 5 of my VDs has over 1500 rows of code each and run continuously. 2 of the runs with fast loops with no sleep or any kind of wait statements. Also I have not even bothered to disable std log data I do not need. Still I have a stable memory utilisation of around 25% + cache ((total around 50%) and very low CPU usage.
How many scenes and VDs do you have?
How many have you written in LUA yourself?
Will your memory usage increase over time (asking as you said you don't want to reboot every nigh)?
/Peo
Edited by pos
Just turn off all scenes, and then check one by one, which one it is. have a second page open to check ram usage from the HC2
    so, 34 scene and 20 vd's
    only one VD (Washing Machine control by @Sankotronic  my lazy + a full power to Sank)  all others scripts (c) 10der
    but I have one slant.
    I hate to use header triggering. and I have a very large code for my scene where I used infinity loops for control devices.
    for example, all lights in my home controlled single script  like a
    and btw, I have disabled all stdout (fibaro:debug) in all my script and VD's
    now all OK
    2days uptime
