[SOLVED]Satel integration 2 way
Hello
I have a question - i need an integration 2 way with satel , is it possible to use fibaro motion sensors to make an alarm in satel ?
Anybody can help with this question ?
I read about integration and i know that i can use satel pir in fibaro but i cannot search about fibaro motion sensor as sensors in satel.
Please help.
5 answers to this question
Hi @miszeli!
It is possible to use Fibaro Motion Sensor (or Door Window Sensor) to trigger an alarm in Satel.
First of all, if you configured Fibaro<->Satel configuration properly, you will have Fibaro zone in Satel.
Then, our Motion Sensor will breach Fibaro zone, if everything was properly armed.
@I.Srodka and what about using the Satel sensors in Fibaro. My house is full of Satel PIR, it should be effecient if I can use them also as triggers for Fibaro.
Hi guys!
@miszeli, it's possible to use FIBARO Motion Sensor to trigger an alarm in Satel.
@Sjekke, it's possible to use SATEL sensor in FIBARO scenes and as triggers.
Ok. Clear!! :)
@I.Srodka Hi! I have a generic door sensor linked to Satel. In Fibaro it shows up as a generic motion sensor. Is it possible to specify it in Fibaro as a door sensor? Are there any workarounds?
Edited by Ros
