Message added by T.Konopka
If you want to upload a file that already has a topic in https://forum.fibaro.com/index.php?/forum/116-crowds-solutions/ remember to contact me in private message in order to merge the topic with the new created here https://forum.fibaro.com/index.php?/forum/446-marketplace-download/. Simply provide me with the link to the old topic and new one.
Thanks!
Forum has been equipped with a tool named
Terms:
and
This is a place where you, users, can share your own solutions with other users.
You can see three categories:
1.
Types of scenes: magic, block, LUA.
Types of files accepted: PDF, JPG, JPEG, PNG, LUA, TXT.
Scenes have to be described properly, screen shots are optional.
Support topics are created automatically here
2.
Types of files accepted: LUA, VFIB, ZIP, TAR, RAR, JSON.
Virtual devices have to be described properly, screen shots are optional.
3.
Types of files accepted: ZIP, RAR, TAR, PNG (each file has to be downloaded separately so if you upload two or more icons then use compression).
Icons have to be described properly and assigned to a correct category.
All files have to be approved by administrators.
Files can be uploaded by any user who is registered on the Forum.
  • Click "Submit File" and select category from the three above.
  • Upload file/s from your device.
  • Provide the title of the file/s - remember that it has to be relevant to the file and should sum up the core of the solution (DO NOT TITLE FILES "LIGHTS", "TV", ETC. - such files will not be approved).
  • Describe the solution thoroughly. Add screen shots if necessary. Make sure that your description will be comprehensible even for not advanced users.
  • Indicate on which system version the solution has been created and mark the solution's version - you can update it! For icons, choose correct category.
  • Finally, accept the terms of submitting files.
After submitting a file, a support topic will be created automatically in the proper forum. The author is responsible for providing support to the solution. If the file will be left without support then the topic will be closed and the file will be marked as unsupported in the DOWNLOADS.
