I want this scene to run only once per day
Can someone tell me what I've done wrong with this scene and if it is possible to get it to do what I want?
The scene is supposed to run once in the morning. It is supposed to turn off everything in my bedroom when the landing PIR is triggered and turn on various devices downstairs, which it does, but it seems to keep running the scene every time the landing PIR is triggered, so if I turn off the Sonos speaker in the kitchen (which had come on correctly initially), then if the landing PIR is triggered again, it starts up the Sonos again, same for any lights I turn off.
Any ideas.
3 hours ago, 10der said:
1) add: setGlobal Action: Set Variable RUNNED = 1
2) add above IF Global Value is RUNNED == 0 THEN you actions
3) create new block scene with time period out of 6AM - 11 AM - SET global value = 0
And a block scene setting the variable RUNNED to "1" from 11AM to 6AM..... I suppose :-)
Edited by 10der
    Like this?
    I created the global variable HasRun=0 and added an (IF #HasRun=0 THEN) before the list of actions in the scene and added at the end of the scene #HasRun=1
    Then created another block scene to reset the HasRun, so that at midday it sets HasRun to 0 ready for the next morning.
    See attachment for my changes to the original scene as per what I understood your suggestions to mean.
