Version 4.160
New improvements:
  • Improved Fibaro Heat Controller support
  • Improved secure communication
  • Improved PIN synchronization stability for Z-Wave locks
  • Added default temperature sets to heating panel
  • Update of devices' states after Home Center start
  • Protection against incorrect Power and Energy values for Fibaro devices
  • Improved notification center for users without admin privilege
  • Improved installed plugins view
  • Updated Wall Plug US icons
  • Frequency information when adding new devices to Home Center
  • Improved control of third party devices included in heating panel zone - manual setting on any thermostat will exclude it from a heating panel schedule for two hours
Resolved issues:
  • No redirection to login page after restoring backup
  • Problem with generating Magic scenes for alarm conditions
  • Problem with saving Blocks scenes
  • Problem with refreshing interactive push scenes
  • Inability to set association in Home Center added as Secondary controller
  • Problem with displaying devices' parameters
  • Problem with controlling temperature sets in heat schedules after time passes 00:00
  • Problem with displaying rooms when Hikvision camera plugin was added to system in Edge browser
  • Problem with displaying grouped devices
  • Problem with refreshing Slider value for Sonos plugin
  • Wrong notification about incorrect mesh network reconfiguration
  • Problem with low battery level notification
  • Problem with not disappearing notification about energy measurement in dashboard
  • Deleted wrong resources from Fibaro Docs
  • Problem with sending multi-line interactive push messages
  • Problem with undefined parameters of Aeotec Siren Gen5
  • Problem with incorrect translations for Fibaro Intercom
  • Problem with 503 error after system startup
  • Problem with operating some devices from the heating panel
  • Problem with displaying LUA and Block scenes when using devices included in security mode
  • Problem with "Arming delay" and "Disarming delay" functions in Fibaro Alarm
  • Problem with Zipato RFID Reader reports handling
  • Problem with block scenes using delay
  • Problem with a delay function used as a condition in block scenes
  • No device grouping section for Fibaro RGBW Controller
  • Minor graphic fixes
  • Minor system fixes
