Hello
i am tying to create a toggle button on my vd. i cant get it to work.
Edited by marius de jong
5 answers to this question
@marius de jong
I found this, perhaps is this wat you looking for.
And in button 1 and 2 you must set a string or a lua code.
And what is what you set on or off?
Edited by Reinhold
    i tryed that solution but it does not work.
    replace 194 with your deviceid you want to switch on/off
    so:
    Local lamp = 128;
    then you do have to replace all the items in the code from christmasTree to lamp
    no it does not work it does not turn it off or on.
    i tryed this code. it goes 0ff and changes the icon to off but it does not turn it on
    local IconOn = 1001;
    local IconOff = 1002;
    local ThisDevice = fibaro:getSelfId();
    if Status == "IconOff" then
         fibaro:call(ThisDevice, "pressButton", "1");
         fibaro:call(ThisDevice, "setProperty", "currentIcon", IconOn);
         fibaro:debug("turned on light");
     else
         fibaro:call(ThisDevice, "pressButton", "2");
         fibaro:call(ThisDevice, "setProperty", "currentIcon", IconOff);
         fibaro:debug("turned off light");
    try this in your VD
    Edited by samuel
    i have it working now. i had to create a global value. "woonkamerlicht"
    and only a 1 button vd
    local value = fibaro:getGlobalValue('woonkamerlicht')
    if (value == '1') then
         fibaro:setGlobal( 'woonkamerlicht', 2);
         fibaro:startScene(20)
     else
         fibaro:setGlobal( 'woonkamerlicht', 1);
         fibaro:startScene(23)
