HomeTable reference in call to change VD ?
I could not find a reference to this issue on the forum, so I have to ask:
Changing a VD setting by     fibaro:call(4, "pressButton" , 6)    in which ID = 4 for a HomeStatus VD  and  VD button number = 6 works fine from a scene , but if I change it in:
fibaro:call( jT.VD.HomeStatus, "pressButton" , 6)   in the LUA of a HeatingOverride VD   it does not work.   Should it work or am I trying to get a round peg in a square hole ?
The goal is to change the HomeStatus automatically to Holiday whenever I program one of the heating zones in the Heating Override VD to Vacation.  . And yes, the VD LUA  has        local jT           = json.decode(fibaro:getGlobalValue("HomeTable"));     in the header and HomeTable is created correctly..
Your help will be much appreciated!
Rudolph
Edited by Rudolph
typo and mistake
    Sorted, just needed a bit of patience and a screen refresh, but LUA worked as planned!
