Backup problems HC2 4.150
HC2 4.150: trying to back up but keep getting errors. Tried all the obvious steps like clear cookies and cache in the browser, restart the HC2, etc... No luck.
Even though I still have enough storage space I tried deleting some previous backups just in case that is the problem: I get an error also: access denied, 403, access forbidden.
Then I checked the recovery tab in the and saw that the Checksum status is Corrupted:
"Corrupted
Calculated checksum does not match (broken image)"
So now I have a system that I cannot backup. I have 600+ devices in 38 rooms, I'm NOT going to reconfigure from scratch...
Anyone has some suggestions?
Some screenshots attached.
Thank you in advance,
APGC
PS: @Fibaro: the frequently requested backup to external devices/locations: when?
Hi @apgc
for 403 error:
#Your alarm panel is disarmed ?
#No running alarm ?
#You're logged in as the admin/superuser ?
Perhaps, this could be a hint:
- Open the WUI of your HC2 and login
- Open http://[IP of your HC2]/api/devices
- Search for "fibaroAlarm":"true"
If you find this string, check the device.
for corrupted issue:
Could be a problem with the USB stick - did you open a support ticket ?
    Hi Orgli,
    Thank you for your answer.
    To answer your question: negative on Alarms active, and no "fibaroAlarm":"true" strings found.
    To the best of my knowledge I'm logged in as Superuser. But how do I check that to be sure?
    Last: corruption: no, I did not submit a ticket yet. Will do that now.
    Thank you again for your help.
    APGC
    For those of you who might have a similar issue: Fibaro Support was contacted, they checked the HC2 remotely and it turns out the USB backup key is corrupted.
    Solution: send the HC2 to Poland. Expected duration: around 2 weeks (!!!!!).
    Fibaro support was very courteous, helpful, but in the end, also helpless... (Thank you Piotr for trying).
    @Fibaro: Guys, you really really need to prioritize the online (or on other devices of free choice) backup solution! A home automation system is a CRITICAL part of a home (In my case heating is completely controlled by the HC2, so I will have to wait until the summer before I send my HC2.
    This is ridiculous...
    Fix this please!
    APGC
