evanbeem 2
Hi there,
When I screw the heat controller onto a valve that does not need an adapter, the knob pops out of the screw ring. This appears to be by design.
If I screw it on less tightly, calibration fails, due to the greater distance between regulator and pusher. Besides, it will just sit loose.
Before I start messing with glue or duckttape, I thought to check in with all the creative minds in this forum. Anyone has any ideas on how to solve this?
(Before this, I used Honeywell Zwave thermostats, but most of them died after 2 years. The advantage of those was that you could fixate them on the regulator with a screw. That is not possible with the Fibaro HC's)
Edited by evanbeem15 answers to this question
