Alarm Panel Configuration
Hi, I have a problem configuring the alarm using the fibaro alarm panel
When I go to the advanced tab and enter in the "Fibaro Alarm Configuration" It goes to a wizard to enter the Pin and " Start Using the system etc.
But I can't configure what sensors will be used, zones, delays, home mode etc
Is there something wrong with my system or this is how the panel works ?
Because I feel it not practical for an alarm panel
4 answers to this question
@Gabriel, welcome to the Community :)
Firstly,  I would like to point out that you have to read descriptions of categories of the forum.
This is the category you posted in:
Quote
Do you have a suggestions about the Forum? Any comments about the Forum? This is the place!
Rules and guidelines
1. Search the forum for similar suggestion, then post it. Duplicates will be deleted.
2. Watch your language!
Secondly, if you post in an incorrect category, your post may be seen by less users.
Finally, you may wait for an answer longer then expected.
When it comes to your post - screen shots are very useful when describing an issue. You can attach them to your original post and depict where you have difficulties.
" to "
Temat został przeniesiony z "
" do "
Hi @Gabriel ,
I'm not sure if I understood you correctly.
You can select and edit/add scenes in the advanced panel and by doing so, choose which devices and under what conditions should be activated.
Simply click Add Action and you can use your own scene with any device, conditions etc.
Let me know if that answers your question.
After you add an new action/scene, how can you remove it again from the panel?
I've tried to click the 'add action' button and then unselect the scene to be removed from the panel.
But my HC froze and I had to reset it manually.
Thx
