Hello
i have several fan coil units in my house.
i would like to make a rule witch lets the ventilator go faster or slower when the room temperature reaches the set point.
So for example on my heating panel the living room is set to 20.5 and the actual temperature is 19 the fan goes to high when it gets within 1 degree of the set point it goes to medium and within 0.5 goes to low.
I have 3 switches connected to the fan fore low-med-high speed
10 answers to this question
Yeah, you are on the right track, but you've got a few subtle things wrong, probably copy paste and decimal point (not a comma).
I think I've removed all the issues, can you please give it a try?
I was thinking to do the same but you cannot rely on the HC2. Sometimes you will need to reconfigure the system after a beta testing or something else and you will end up with no heating. In order not to depend of Fibaro, I have bought thermostat controller MCO Home MH8-FC - Fan Coil Thermostat 2 pipe and connected with 2 wires for starting the boiler. All the thermostats in the house I have connected the water valve contact in parallel, giving command to the starting relay of the boiler so, even if the Fibaro it is not working, the heating system can be operated  manually on each room. In this case you will need to set up desired temperature on the thermostat and will start and stop the fan unit according to that temperature.. The heating panel from Fibaro is just sending me scheduled temperature set point but the thermostat unit is deciding if need heating on low, medium or high speed of fan, changing them automatically.
Edited by silvinnio
    i have 1 of does but i do not have wires running from all the fan coils to a remote thermostat. so i need to control them via relay's and scene.
    i got this rule but i cant get to compare difference of 0,5 to each other
    %% properties
    %% events
    %% globals
    local Tempratuurverschil = fibaro:getValue(50, "value")
    local Setpointwoonkamer = fibaro:getGlobalValue("Setpointwoonkamer")
    fibaro:debug(Tempratuurverschil)
    fibaro:debug(Setpointwoonkamer)
    if fibaro:getGlobalValue('Setpointwoonkamer') == Tempratuurverschil
    then fibaro:debug("are equal")
    else fibaro:debug("are NOT equal")
    if fibaro:getGlobalValue('Setpointwoonkamer') -0.5 < Tempratuurverschil
    then fibaro:debug("is lower")
    else fibaro:debug("is not lower")
    @silvinnio I agree... It is my personal opinion, always use a "thermostat" device for temperature control. If you depend on controller + algorithm + batteries + perfect network communication and so on you could have a nasty surprise some day! Image you use a Door/Window sensor in your living room. It reports "18 °C" and then its battery dies (you did not notice, you forgot to check or it has a bad battery). Your script turns on the heating system... When is it going to stop? When are you going to notice? What is going to limit the temperature in that room? If you use a thermostatic device (radiator valve, or electrical on/off thermostat, any thermostat) and set it to some high temperature, like 28 °C at least you know it is going to stop at around 28... And setting it to 28 probably was intentional, unless children have played with the settings.
    I think it is better to do tonumber() on that global variable. In fact, it is always better to do that, even when calling fibaro:getValue. Then print the number, do the math and do the comparison.
    i get an error
    %% properties
    %% events
    %% globals
    local ruimtetempratuur = fibaro:getValue(50, tonumber("value"))
    local Setpointwoonkamer = fibaro:getGlobalValue(tonumber("Setpointwoonkamer"))
    fibaro:debug(ruimtetempratuur)
    if fibaro:getGlobalValue('Setpointwoonkamer') <= 0,5 ruimtetempratuur
    then fibaro:debug("is lager")
    fibaro:setGlobal('test',0)
    else fibaro:debug("is niet lager")
    fibaro:setGlobal('test',1)
    if fibaro:getGlobalValue('Setpointwoonkamer') >= ruimtetempratuur
    then fibaro:debug("is hoger")
    else fibaro:debug("is niet hoger")
    11 minutes ago, marius de jong said:
    i get an error
    Tell me all about it, you got me all excited!
    Or do you want me to guess which error? I can do that, I like a challenge!
    Edit: that is an honest question, I really like to guess ;-)
    Edited by petergebruers
    if i do it thisway
    %% properties
    %% events
    %% globals
    local ruimtetempratuur = fibaro:getValue(50,"value")
    if fibaro:getGlobalValue('Setpointwoonkamer') <= 0.5 ruimtetempratuur
    i get:
    /monthly_2018_01/image.png.09a3c7229e711b113244857b4c09bea6.png" alt="image.png.09a3c7229e711b113244857b4c09bea6.png" />
    if i do it whith the tonumber( )
    %% properties
    %% events
    %% globals
    local ruimtetempratuur = fibaro:getValue tonumber((50,"value"))
    local Setpointwoonkamer = fibaro:getGlobalValue tonumber(("Setpointwoonkamer"))
    Thanks petergebruers
    It works. I added medium en high modes so now when room temperature is 0.5 lower than room set point fan goes to medium, and when the difference is more then 1 it goes to high,
    on/off of the low speed is working via the heating panel
    %% properties
    %% events
    %% globals
    local ruimtetempratuur = tonumber(fibaro:getValue(50, "value"))
    local Setpointwoonkamer = tonumber(fibaro:getGlobalValue("Setpointwoonkamer"))
    if ruimtetempratuur <= Setpointwoonkamer - 0.5 then
      fibaro:debug("ventilator midden aan")
      fibaro:call(17, "turnOn");
    else fibaro:debug("ventilator midden uit")
      fibaro:call(17, "turnOff");
    if ruimtetempratuur <= Setpointwoonkamer - 1 then
      fibaro:debug("ventilator hoog aan")
      fibaro:call(15, "turnOn")
    else fibaro:debug("ventilator hoog uit")
         fibaro:call(15, "turnOff")
    That's super! Have fun!
    @marius de jong
    To avoid simple coding errors. This is actually good for both beginners and pro:s..
    I suggest use of the free Visual Studio Code editor with "lua lint" (from satoren) plugin. I use it on MAC, but it runs on all OS:es. This editor do supports handling of unicode charachers  which is not the case with for example Notepad++ (that I know is a popular editor on windows)
    (But of course there are more good editors. Non free Sublime for example)
    Then I also suggest a Git repo and any of the Git plugins.
    I´ll attach a screenshot...
    /Peo
    Edited by pos
