D4RK1 0
hope someone can help me. I´m new to LUA and programming in general and I am trying to get a simple (so I thought) scene to work.
What I want to do:
I have a lamp in my dining room which is connected to a fibaro rgbw controller. I have two (or maybe three) wall switches connected to fibaro dimmer 2 and fibaro double switch 2. The lamp and switches are working as they should. If I program them indepently, they control the lamp.
Now I want to have them control the lamp together. So if either of the switches is set to "On", the lamp should switch On as well and vice versa.
I have been fiddling around with several ideas but nothing works as intended. Right now I am trying 2 switches and 1 lamp, I might want to add another switch later, but that is not important now.
Currently I am thinking that I need to change the value of the "other" switch to match the switch I used to control the lamp.
Meaning I Turn Switch1 "On" and Lamp and Switch 2 are set to "On". The problem is, the state change of Switch 2 triggers the scene again. At least I think that is the problem.
I cannot believe that I am the first or only one that wants to control 1 lamp with several switches.
If someone has a working script for this, please share =)
Regards, Jens
